I am having trouble getting Snippet to work directly on the Desktop. In all other locations, Hotkey works fine, the problem is only on the Desktop. The key sequence
Ctrl +
Space inserts the _ character (in file name edit mode)
The following prompt is displayed
My config
I have checked the AutoHotkey script, it works on the Desktop without any problems.
Can you check this for yourself?
